phone setting while traveling in US
What do you set your phone to when you buy a US text message only bundle? I want to avoid any surprise charges
Photo of Rhonda Gallant
Rhonda Gallant
Photo of Sophia
Sophia, Mobile Master
You should disable data, Rhonda to avoid roaming fees :) If you tell us what phone you have we can help with the settings. Happy travels!
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
To shut off data on Android you can do the following steps:
Select Settings - Data Usage - Mobile data switch to off.
Hope that helps :)
