Phone replacement
Hi I have an iphone 4 8g with a 3 year plan.. My phone recently fell, the screen is damaged and the lock button does not function very well. What can I do to change the phone or get the iphone 5 instead and how much should that cost? Thank you.
Photo of Sarah Elias
Sarah Elias
Posted 3 years ago
Photo of Chris Petersens
Chris Petersens
  • 47,246 Points 20k badge 2x thumb
Well, the new phone will cost quite a bit. Apple can fix the screen for you, it's about $30 if it's just cracked.
I thought three year plans were gone for quite some time. Maybe even 3 year. Which means you could use their TAB and pick a new plan if you want. Just go to a koodo store and they will tell you what options you have.
Photo of Daniel Kim
Daniel Kim, Mobile Master
Well the good thing Sarah is that there are no longer 3 year plans.
So here are some options:
You could buy a used phone (unlocked or locked to koodo/telus) and use that until your tab is cleared then buy a new phone.
You could pay off your tab now and get a new phone right away.
As for PRICE (once tab is cleared)
It will cost 275 for an iphone 5s on tab M. (requires plan over $30) And 525 on Tab S
For the 5c, 125 on tab M, 350 on tab S
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 192,584 Points 100k badge 2x thumb
You can go to your local Koodo kiosk and there you can pay off what you owe still on your tab (amount owing on the old phone) and then choose a new tab and get the phone you want. You have various tab options with the new small, medium and large tabs, and each will take a different amount off of the initialpprice of the new phone. I recommend going with a medium Tab which will take $300 off the initial price of the phone at the point of purchase. It requires a plan of $30 or more and will have a $5 per month to charge to help pay off the tab as well as Koodo will pay off a piece of your tab at a rate of 15% of your bill each month.
There will also be a 2 year guarantee that your device will be paid off in full by the 2 year mark even if you haven't paid it off all yet from the monthly contributions from you and Koodo which is always a great thing.
Visit your local kiosk and they will explain everyooption you have further
