phone not working
My son just informed me that his phone is not working for some reason and cannot call people. Can you please let me know why?
Photo of The Goedike's
The Goedike's
Posted 3 years ago
Photo of Dennis
Dennis, Mobile Master
I assume your is bill paid up, texting continues to work, and he has signal on the phone.
Try rebooting the iphone?
Photo of Dave
Dave
  • 7,814 Points 5k badge 2x thumb
is it calling, or call and text - my first thought is that you need to enable 3G (on iphones it is settings - cellular - enable 3G)....keep in mind that enable 3G does not turn on data.
Otherwise the first thing that I would do is pull my battery and SIM in case it is just a problem with an update or the phone)
Photo of rikkster
rikkster, Mobile Master
  • 66,988 Points 50k badge 2x thumb
It's an iPhone. You can't remove the battery.
Photo of Dennis
You can. Just with extreme difficulty and special tools
http://www.imore.com/how-replace-batt...
Photo of Dave
Dave
Did you try to enable 3G?
Koodo does not have 2G service so 3G must be enabled all of the time.
Since it is an iPhone, a similar way of pulling the battery and SIM's (in androids), is to put phone in airplane mode, take it out of airplane mode, and then turning it on and off - so you do not void any warranty by pulling the battery
But thank you for telling me it is an iphone
Photo of rikkster
I realize that Dennis, lol. Though in this instance, it doesn't seem very practical.
Photo of rikkster
A hard reset or reset is more akin to a battery pull. Placing the iPhone in Airplane mode simply disconnects the phone from the network. Resetting network settings is another method to try if having problems accessing the network.
