Phone not charging
How long does the phone need to be charged for?
Photo of Alijah Martin
Alijah Martin
Photo of Robert
Robert, Mobile Master
  • 101,454 Points 100k badge 2x thumb
The time it takes for the battery to get to 100%. Depends on the phone but I'll say +/- 3h
Photo of Jonathan I
Jonathan I, Mobile Master
If you're using the USB port on a computer, those charge very slowly because they're typically only designed for data transfer. They will charge it, just slowly.
If you're using a wall adapter, find one that a higher mah output (cord doesn't matter). Generally speaking, the higher the mah output, the faster the phone will charge, but the phone will also only draw as much power as it needs so it could just be the same. Just don't get one that's only 1A (1,000 mah) unless you have a tiny phone with a small battery.
Shouldn't take more than 2 hours.
