Phone keeps sending same texts to people
  • 3
  • Updated 1 year ago
Can someone help me figure out why my phone keeps sending same text to people, suddenly started sending people the last text sent up to 6x
Help!!!
Photo of Jack Williams
Jack Williams
  • 80 Points 75 badge 2x thumb
  • Annoyed
Posted 1 year ago
  • 3
Photo of Robert
Robert, Mobile Master
  • 106,744 Points 100k badge 2x thumb
Hello Jack,
Are you in a low signal region? Maybe the phone thinks it didn't send the text when it actually did? Did you try restarting the phone to see if the problem is solved?
Photo of Allan
Allan, Mobile Master
  • 61,880 Points 50k badge 2x thumb
Are you using a third party texting app? If so try using the stock one and see if that makes a difference.
If you have another phone or can borrow a friends, pop your sim card in that in see if it still sends duplicate messages.
Photo of joe depetris
joe depetris
  • 62 Points
I've had the same problem delayed messages and sent multiple times I have friends on koodo who are having the same issues when the message me my messages look fine on my phone but on the receivers end it was sent 3 to 5 times turned my phone off for 5 minutes and it seems to have corrected
Photo of Tina Fyvie
Tina Fyvie
  • 92 Points 75 badge 2x thumb
This is happening to me too.  First time yesterday with one particular txt  and today it's doing it again but with different txts. ...and it's driving my friend crazy.  It doesn't show the repeats on my phone.We have tried both turning off our phones and it's happening again today.  What is going on?  I have the Samsung S5Neo...he's got iphone.  It even happens when my phone is turned off!!  Please help!!!
Photo of Tina Fyvie
Tina Fyvie
Photo of Tina Fyvie
Tina Fyvie
I just posted twice...not through my phone lol...
Photo of Ray Pregent
Ray Pregent
I callled Koodo  (611) and they reset everything over the phone and I deleted the text conversation with my buddy that was getting all the texts I didn't send. Seems to be working
Photo of Tina Fyvie
Tina Fyvie
Ok thank you Ray!  I have deleted the entire conversation and had my friend do it too.  I also took out the battery.  So far so good but if it happens again  i will call Koodo for a reset.
Thanks again!
Tina
Photo of rikkster
rikkster, Mobile Master
  • 68,228 Points 50k badge 2x thumb
To expand on Ray's comment, I was experiencing the same issue yesterday and earlier today. A call to Koodo's tech support department (611, options 6 then 2) appears to have fixed the problem. The rep will ask you to power off the phone for five minutes while he or she does a network reset at their end. Wait time was less than ten minutes and the rep was courteous and helpful. Thanks for the tip, Ray.
