phone jumping in and out of connection
  • 2
  • Updated 3 months ago
iphone 5S will not stay connected to network - in and out a few times a minute - wifi works - tried restarting, tried removing and reinserting SIM card, no luck - been going on since yesterday
Photo of Marco Voets
Marco Voets
  • 80 Points 75 badge 2x thumb
Posted 3 months ago
  • 2
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,898 Points 100k badge 2x thumb
Are you in a different area from where you usually are where you may just not be getting a good signal? Or has any new buildings went up around you that could interfere with signal?
Are others on Koodo Telus or bell around you having the same issue?
Photo of Dennis
Dennis, Mobile Master
  • 196,772 Points 100k badge 2x thumb
Try settings >reset>reset network settings.
Note that Bluetooth and WiFi passwords will be lost
Photo of Allan
Allan, Mobile Master
  • 62,804 Points 50k badge 2x thumb
If none of the above works you can take your phone to a koodo kiosk and have the sim tested to make sure there's no problems with it and get a new one if there are problems.
