phone acting strange
Im having a problem with my galaxy ace phone.when my battery charges it shows 100 percent , then after I use it a for awhile the battery indicator will show 100 percent and doesnt change even if I use it alot and then it just shut off..then when I try to re-start it it shows the battery is almost dead...then it can sit hooked up to the charger but it wont charge unless I hold in on the start button and plug it in while it is powering up..Then it will stay on and charge for a bit..pain in th ebut at the moment..Is this just the case of a bad battery?
Photo of Brent LaPointe
Brent LaPointe
How long have you had this "device"?
Photo of matthew sider
matthew sider
  • 746 Points 500 badge 2x thumb
Make sure you clear the running apps in back round
by using clean master or push the home key
should do same work if this keeps up do a software reset if dosnt work hard reset if call koodo
your phone may need flash my help
that sounds like software issues
simple reset my help please injoy your day
This device is way past it's useful existence. It's starting to show its age as well.
You could try a factory reset as Mr. Sider may have mentioned above but you might have better luck using this device as an ornament on your holiday tree.
If you have room on your tab I'd recommend upgrading your device to basically anything Koodo currently offers. Today's devices are better in every conceivable way. Better battery, better screens, better storage, faster speeds
Your problem might just be the battery and you could probably pick one up on ebay for under 5$ but Tb, I wouldn't bother.
Photo of Du
Du
  • 3,762 Points 3k badge 2x thumb
Sounds like you might need a new battery, its 10-15 dollars on eBay, that should hold you over until your tab clears for an upgrade
