Pay-per-use Data Saver?
Just so I can understand the Pay-per-use Data Saver add-on that comes with the $20 Canada-wide Talk+Text plan, if I don't use, let's say 100MB, but used over 25MB, would I be charged only the $5 for the 25MB?
Photo of IncendiaryPyro
IncendiaryPyro
  • 132 Points 100 badge 2x thumb
Photo of Marcus Fenix
Marcus Fenix
  • 15,752 Points 10k badge 2x thumb
Yes.
Photo of Starfox
Starfox
  • 5,718 Points 5k badge 2x thumb
Once you hit 26MB, the $10 is billed, no?
Photo of Camilo_A
Camilo_A
  • 31,746 Points 20k badge 2x thumb
Right!!!! between 25 MB and 100 MB you fall into the 10$ bracket!
Photo of Sophia
Sophia, Mobile Master
If you use between 25 and 100MB (say, 26MB), then you will be billed the next tier up from $5, which is $10... so the answer is not really "yes" in this case, I'm afraid...
IncendiaryPyro
Ah, that does seem to make more sense. Thanks for the enlightenment.
