Padfone2 does not seem to work with Koodo Sim
  • 2
Padfone2 does not seem to work with Koodo Sim. After inserting Sim, it says No Service initially and after sometime shows Emergency Calls only option
I tried turning off mobile data but still see the same thing
Photo of ArViL RaI
ArViL RaI
  • 80 Points 75 badge 2x thumb
  • 2
Photo of Daniel Kim
Daniel Kim, Mobile Master
Is it unlocked?
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
Did you confirm that phone is compatible with Koodo?
http://koodomobile.com/en/on/switch2k...
Mobile data has nothing to do with the overall connection.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Make sure you don't have it set to 2g or GSM Only
Zaphod Beeblebrox
Being in tech support, you would think I would remember to add that to my posts hahaha.
Photo of Daniel Kim
LOL another star for paul, totally slipped my mind
Let us know if you get it working and what solved your problem so we can help others possibly with your same issue using the padfone series of devices. The KS
Photo of John Burke
John Burke, Mobile Master
Did you input the Koodo APN?
Zaphod Beeblebrox
Ugh...it would be great if a response is posted. I hate when this happens....
Photo of Daniel Li
Daniel Li
  • 62 Points
same... i need help...
Photo of Daniel Kim
Here to help! If your question is about the padfone 2 compatibilty, then it would have to be a model that supports HSPA 850/1900. Once you figure out if your phone includes this, you need to get it unlocked. Cellunlocker.net or gsmliberty are pretty good 3rd party unlocking services. After all of this is done, it should work. I wish the OP of this thread responded to confirm...
Photo of A Rai
A Rai
  • 60 Points
Hey Guys, Unfortunately Padfone 2 does not work with Koodo. Even though the Koodo guys say that it would work but it doesn't work.
I switched to Rogers and it works without any prob...
