Out for repairs, switch phone number to old phone?
I have to send my iPhone 5 away for repairs to the battery. It will be out of my hands for about 2 weeks. How can I change my phone number over to an old talk and text phone that I have?
Photo of Loni Horsley
Loni Horsley
  • 90 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Ahmad
Ahmad
Just log into self-serve (the old self-serve) and I believe it was under the "Phone" tab. Go to change my phone/sim card and follow the steps from there
(I'm assuming it's a CDMA phone. I'm not sure if CDMA phones can still be activated on the network).
If it's a phone with a sim card, you just need to purchase the appropriate sized sim card from a Koodo store or Best Buy/Future Shop
Photo of Ahmad
Ahmad
Good point! I get mine online.. a half dozen for a couple bucks lol
Photo of Justin Robichaud
Justin Robichaud
  • 5,002 Points 5k badge 2x thumb
That works too haha!
Loni Horsley
Does my iPhone have a SIM card that I can just pop out?
Justin Robichaud
Sure does. On the right side there's a little poke hole. Just pop a paper clip or an earring in there and the tray pops out.
With the adapter you just snap your tiny card into an adapter that will make it bigger to a micro or standard.
Photo of David
David, Mobile Master
  • 88,942 Points 50k badge 2x thumb
Yes, in the drawer on the side. You will need to push a small paper clip, or the tool which came with the phone into the small hole to open the drawer.
Photo of David
  • 88,962 Points 50k badge 2x thumb
If it is a SIM-based phone, you can get a SIM card to fit it and move your phone number to the new SIM in self-server. You can then transfer the number back to your old SIM card when your iPhone is returned to you.
If it is an old CDMA phone (no SIM) then it won't work.
Apple, or Koodo might offer you a loaner phone if you approach them directly as ask for help. You would likely need to take your phone to a physical location to request this support.
Loni Horsley
My physical location couldn't supply me with a loaner, nor would Apple when I contacted them. Top it off, my old phones aren't supported on Koodo network and have no SIM card= no dice. Would my friend's old iPhone 3C (which was on a telus plan) work?
Photo of David
  • 88,842 Points 50k badge 2x thumb
Yes, the iPhone 3Gs, or even the 3G should work on Koodo.
