OS upgrade problems for LG optimus one
  • Updated 6 years ago
hi - i follow all the steps outlined but when i start the update tool my phone is not recognized. the phone is connected to the computer and in fact can be seen by the computer, but the upgrade tool continues to tell me to connect my phone. please help. this is so frustrating.
Photo of Ted Mcdonald
Ted Mcdonald
Posted 6 years ago
Photo of Aaron MacIntyre
Aaron MacIntyre
  • 10,050 Points 10k badge 2x thumb
are you running a mac or windows? and if windows, what version?
Possibly you need drivers. I know that doesn't make sense since your computer sees them, but windows has a habit of slapping a one size fits all drivers on phones, and it can cause issues interfacing with the actual phone software you're running on your computer
Ted Mcdonald
windows 7. i downloaded and installed the drivers from the LG website and then installed the upgrade tool
Ted Mcdonald
now i am being told by LG that no upgrade is available for my carrier, even though it explicitly states on the carrier's website that i need up upgrade the version that i am currently running.
Aaron MacIntyre
K, well try a reboot if you haven't already. That and what version of android is your optimus one running right now?
Edit: Reboot both the phone and computer for giggles
Ted Mcdonald
version 2.2.1. rebooting doesn't make a difference. koodo is telling me there is an update available but LG is saying there isn't, and that's why the update tool is not working. what fun.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,838 Points 100k badge 2x thumb
Can you post the URL of the page telling you that you need to update?
Aaron MacIntyre
http://koodomobile.com/en/on/upgrade_... I believe is the page he maybe looking at
Ted Mcdonald
Ted Mcdonald
koodo confirms there is no update. apparently the website is incorrect then.
thanks for helping out guys.
Aaron MacIntyre
Well, actually the site is correct. There WAS an update, obviously they are not offering it anymore.
If you really want that update, check out the optimus one section on xda:
http://forum.xda-developers.com/forum...
Heads up that rooting and what not will void your warranty, but I'm guessing your warranty is probably expired by now anyway.
Ted Mcdonald
ok. thanks.
Photo of rikkster
rikkster, Mobile Master
The advantage of rooting is that it's completely reversible. Un-rooting your device is a fairly simple procedure. The only way you'll void the warranty is if you send your device back to the manufacturer or Koodo in its rooted state.
