Number changed....still can't use phone . HELP!!
I recently applied online for a number change for my LG Banter (cdma) phone. All went okay, until I tried to send a text....I could not use my phone at all. I tried the instructions given for programming online, but was unsuccessful. I do not have a landline to call koodo from, as my cell is my only phone. How can I get my phone activated again?
Photo of Juanita Muise
Juanita Muise
  • sad
Photo of Camilo_A
  • 30,198 Points 20k badge 2x thumb
Hi there Juanita... this number change, was for a number that was active somewhere else that you are porting to Koodo? Or was it simply a number change for a random number?
Meanwhile try to reprogram your cellphone by doing the following:
On the handset, dial *22803 + send.
Keep up posted...
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
Any luck on the number situation, Juanita?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 137,052 Points 100k badge 2x thumb
If *22803 doesn't work, you will have to call koodo from another line since they'll need to walk you through manually programming the phone. The toll free number is 1-888-995-6636.
Photo of MarioB
  • 370 Points 250 badge 2x thumb
If the manual programming does not work, then it's a handset issue.
