Nougat Problems
  • Updated 2 years ago
upgraded my One plus 3 to Nougat and now my data does not work. Any suggestions?
Photo of patrick
patrick
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Goran
Goran, Mobile Master
  • 96,868 Points 50k badge 2x thumb
Try pulling out your Sim card and putting it back in and restarting your phone. If that doesn't work check your ApN settings to see if they've been changed since you upgraded.
Photo of Phil Arcand
Phil Arcand
Same problem here with OnePlus 3T. Pulling the SIM card out and in again did not help, nor did rebooting.
Phil Arcand
Changed the APN with the settings found on this page and it worked. Thanks Goran.
http://aide.koodomobile.com/plans-add-ons-data-and-other-services/data-on-android/How-do-I-setup-dat...
Photo of patrick
patrick
Thanks!!!!
After adding the settings everything is good.
Photo of Goran
Glad it worked! Thanks for letting us know it did.
Photo of Lloyd Willett
Lloyd Willett
  • 3,688 Points 3k badge 2x thumb
Is this nougat upgrade available for the lgg4 and if so is it better than what's on the lgg4 right now thanks
Photo of titaniumtux
titaniumtux
  • 12,952 Points 10k badge 2x thumb
No word on the LG G4 (see link). LG's are not generally the fastest at getting Android updates, but not the slowest, either.
