Notification sound problem
  • Updated 3 weeks ago
I Have a problem with my phone. the text message notification is not working. I have already checked both phone and message settings and it has sounds when i played it but when i received a message there's no sounds. Please help me fix this.
Photo of loida mar
loida mar
  • upset
Posted 3 weeks ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 206,114 Points 100k badge 2x thumb
Is do not disturb on? If it is turn it off
Photo of loida mar
loida mar
No it is not.
Photo of Mats
Mats
  • 24,012 Points 20k badge 2x thumb
What phone do you have and what texting app do you use?
This thread has alot of replies and solutions that worked for some users. Might be worth a read.
https://www.ifixit.com/Answers/View/136077/no+notification+sound+on+text+messages
Photo of loida mar
loida mar
It is already uncheck and nothing happens
Photo of Mats
Mats
Restart the phone if you havent. Sometimes fixes things.
Photo of loida mar
loida mar
I am using s6.. And i am using the regulai messages that was already installed on my phone.. I used to have the go sms but lately i had the problem using it like i can't receive messages so i decided to uninstalled it.
Photo of loida mar
loida mar
I already reboot my phone and it didn't help.
Photo of Allan
Allan, Mobile Master
  • 65,436 Points 50k badge 2x thumb
Do you have notification sounds turned on. Phones (android phones especially) can have like 4+ volume sliders for different things. You may think you have the volume turned up all the way even though you dont.
Photo of loida mar
loida mar
I have also checked the volumes... they are all loud enough to hear.
Photo of Robert
Robert, Mobile Master
  • 109,202 Points 100k badge 2x thumb
Have you tried restarting the phone to see if it solved the problem?
Photo of loida mar
loida mar
Yes i already did.. That is the first thing i did and nothing happens.
Photo of rikkster
rikkster, Mobile Master
  • 68,940 Points 50k badge 2x thumb
Tap 'Allow notifications' (shown in your picture) then look for and tap Sound. Tap the selection 'default notification sound'. By doing so, it should play a sound. If you don't hear a sound played, continue to tap on the default notification sound, while at the same time, increase the volume level using the side volume up button. You should be able to hear the notification sound now.
