Nothing but problems with messaging
  • Updated 2 years ago
I just set up an account for me and my brother and ee both got the lg G3. Both will randomly not send any messages. The bars are full and phone is not on airplane mode. Is it my new phone causing the problems or koodos coverage? To get anything to send we have to turn off our phones.
Photo of Shannon Paulitzki
Shannon Paulitzki
  • frustrated
Posted 2 years ago
Photo of Robert
Robert, Mobile Master
  • 106,940 Points 100k badge 2x thumb
Did it just start happening? Or your phone had the problem since the beginning?
Shannon Paulitzki
About 2 or so weeks after I got it. When I called they basically said does it work when you turn it on and off. And didn't have any other suggestions
Photo of BobTheElectrician
BobTheElectrician
  • 67,356 Points 50k badge 2x thumb
An option here: try !Textra.
https://support.t-mobile.com/thread/95247?start=0&tstart=0
That will establish if it's a software or handware issue.
Did you guys come from another carrier and bring your phone numbers with you? You may have to wait 24hrs for your numbers to fully port over.
Shannon Paulitzki
Sounds like from the link posted above it may be a g3 problem. And yeah we brought out numbers over but it's been a month now
Photo of Melissa
Melissa, Employee
  • 11,748 Points 10k badge 2x thumb
Are you having any problems with calls/data?
Shannon Paulitzki
Never noticed anything with calls but don't call much. And data can be tremendously slow at times
Photo of Tayeb A
Tayeb A, Employee
  • 18,208 Points 10k badge 2x thumb
Thanks for your reply Shannon :) If you experience some sluggishness with some apps on your LG G3, I would recommend clearing the cache for individual apps by following these steps:
From a Home screen, navigate: Apps > Settings > Application manager.
1) Tap the appropriate app (Example: Facebook)
2) Tap Storage.
3) Tap Clear cache.
4) Clear All Cached Data
Note: This option may not be available for some apps.
You cal also clear all cached data at once:
From a Home screen, navigate: Apps > Settings > Storage & USB.
If memory card is installed, tap Internal storage.
1) Tap Cached data.
2) Tap OK to confirm.
Hope this helps!
