Note 5 not asking for unlock code
  • Updated 7 months ago
  • (Edited)
I switched from Telus to Koodo yesterday. But it doesn't ask me for unlock code after restarting the phone with Koodo sim inserted. Please help. I have tried #7465625*638*# and it doesn't work.
Photo of ben
ben
Posted 7 months ago
Photo of Allan
Allan, Mobile Master
  • 62,804 Points 50k badge 2x thumb
It shouldn't. You can use a Telus phone with Koodo and vice versa. If you're getting service than you're good.
Photo of ben
ben
On the lock screen, it says No Sim - Emergency Calls Only. I do see the signal bar is full. But it says not registered on network when I try to make a call.
Photo of Dinh
Dinh, Mobile Master
  • 42,176 Points 20k badge 2x thumb
I would try to reset the network settings and see if it help.
Photo of ben
ben
That didn't work either. :(
Photo of ben
ben
Photo of Dinh
Dinh, Mobile Master
Last month someone used a telus SIM in my koodo phone. It took 2 restart to make the phone work. I would suggest you restart it again and check the Sim like Paul mentioned below
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,898 Points 100k badge 2x thumb
Are you sure your SIM Card is activated on the account already? Try bit in a different phone if possible. When did you activate the SIM?
You'll also need to change your APN settings if it doesn't automatically change it to Koodo's when putting the active SIM in.
Photo of ben
ben
Thank you for the suggestion. I tried another Koodo sim in my phone and it worked fine. I tried the my Koodo sim in an Iphone and it showed the No Sim message. So I am guessing my sim card is :f'ed. I got it from Best Buy yesterday around 7PM. Any way to fix this without going to a store?
NP if that SIM Card has been activated and its not working I'd visit Best buy and let them know and they should give you a new one if the SIM is defective.
Have a great night Ben.
