Note 2 data drop problem...
When my data is on, my phone will constantly drop the connection (both data and bars) to the little no signal sign... on and off.. essentially making the phone useless without wifi.
I've tried all of the solutions here (turning off auto connect, LTE, etc.,) but it still has the same issue. Has anyone figured out a new solution?
I've seen some people saying the issue might be kitkat 4.4.2?
Photo of colinnium
colinnium
Photo of Yannick
Yannick
Hi there, you should contact our technical support at 1-866-995-6636 from another phone, option #6. If your phone needs to be sent for repairs, the rep will be able to explain you how to proceed: http://koo.do/JVO5Mk :) Thank you!
________________________
