not sure what to do if i am changing providers
I am thinking of changing providers should i wait and let you transfer or do I go ahead and cancel then call you
Photo of Laurel Keating
Laurel Keating
  • 170 Points 100 badge 2x thumb
Photo of Iglooman
Iglooman
  • 4,090 Points 4k badge 2x thumb
Koodo will take care of it. They just notify your current provider that they are taking over your number and that's that. Was easy as pie when I went to my Koodo booth, and I make pie REALLY easy...
Laurel Keating
thanks for the advice
Photo of Jessica Pixner
Jessica Pixner
  • 142 Points 100 badge 2x thumb
Ya Koodo staff will take care of everything, it's always great to ask the questions when you visit a Koodo stand or store in the mall before making any quick decisions. :)
Photo of Iglooman
Iglooman
Best part is, I never had to talk to me old provider again... Yay! :)
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
If you want to port a number to koodo the account with the old provider MUST remain active until the port is complete. The act of porting the number to koodo will automatically cancel the line with the old provider.
Laurel Keating
thanks so much
Laurel Keating
ok that is good to know i never knew that thanks so much
Laurel Keating
okay that is good to know also, I am not sure what plan I would get, is there something that is unlimited anytime talk and text in canada and or both usa and canada, or i guess i can just call them and find out,
There is unlimited talk and text in canada starting at. 50$ per month.
Photo of G R
G R
  • 2,090 Points 2k badge 2x thumb
To make sure you don't get double-dipped too much, call your old provider and ask to have them switch you to their cheapest plan, and tell them to pro-rate the billing as of this call.
Technically you have to give old provider 30 day notice, and if you don't they charge you an additional month, but this is not recommended, as they can "lock" your phone number and prevent it from being ported.
Pro-rate means as of now, otherwise they will switch you next billing date, and this won't help since you will no longer be with them!
Photo of G R
G R
Although this is true, some companies have been known to delay the port such that it goes over your 30 day notice, and blame the porting-to company on not filing properly.
Photo of Ness
Ness
  • 2,700 Points 2k badge 2x thumb
The only reason that would happen is if your did not give enough time for the port to go through, If you port out on the last day of your billing period it will almost always carry into the next month. I recommend starting the port min 3 days before the bill cycle end date. If you port out on the last day of the billing period the previous company cannot cancel your line because of there are any delays in the port or it didnt go though then the line would be cancelled and you would lose the number.
Photo of Ahmad
Ahmad
A provide CANNOT "delay" a port because it wants to. Systems will not allow it. Vanessa is right, some people just don't give enough time for the port to happen because it can sometimes take more than a day.
Photo of G R
G R
Again, for the most part, its smooth sailings, but there are some things that can trigger a delay, which seems trivial in nature, and nothing to do with a time delay. Add to that internal notes are used, and due to Privacy Act, one provider can't tell another provider what the problem is except with technical codes.
From what I've read in the past from former porters, the 3 biggest things that can delay a port and cause it to go overtime-as most people leave it for the last possible "legal" time to port (in no particular order):
1. User's name has a minor typo, or the street is abbreviate in the bill but not the port request (and vice-versa);
2. User want's to port a number from an area code not serviced by the new provider to be used in an area serviced by them (usually with regional providers), or from province-to-province. There is nothing in the CLEC rules that you can't port from one area to another, but some companies don't care.
3. User ports number from provider A to provider B, then later decides to port back to provider A. Provider A sees a technical error as it was an exchange that they already own, and claims a port isn't necessary as its already their exchange.
The above scenarios are getting fewer and fewer as programmers are updating systems with these out-of-the-ordinary ports, but these and others still do exist.
As for the "its illegal to do so" defense, have you checked out their legal depts, or as I like to call them the loophole finders! One of the reasons why the CCTS exists (http://www.ccts-cprst.ca/).
Laurel Keating
i know since my contract ran out they call all the time, rogers that is
Laurel Keating
k thanks again
Photo of Camilo_A
Camilo_A
  • 31,032 Points 20k badge 2x thumb
To add something on the plan that Chad recommended, you may think about adding the LD saver that will give you access to a preferred rate to CALL the USA while you are here in Canada (0.05$/Minute), then if you are crossing the border, you may call Customer Service to get some info on the roaming packs offered for text and voice.
Laurel Keating
thanks so much
Laurel Keating
ok sounds awesome
Photo of Camilo_A
Camilo_A
NP... check the rates for more countries
