Not so Intense
My Samsung Intensity 1 doesn't want to receive music from my laptop. Does the music need to be bought through the mobile browser in order to show up on the phone? I'm gonna try to sync the phone with my PS3 music now. I can't sync music from my laptop, kinda frustrating though. I have a 16GB MicroSD card too, ugh!
Photo of Aaron Heinrichs
Aaron Heinrichs
  • 768 Points 500 badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 193,200 Points 100k badge 2x thumb
After you transfer the music to your phone try turning the phone off and then back on then check for your music. All the Samsung phones I've had you need to power the phone off and on for it to see the music on the device after first putting it onto the phone.
Photo of John Burke
John Burke, Mobile Master
Instead of rebooting, you can get an App to "Refresh" the media.
There's a bunch available but I have had best results using "SwitchPro Widget" from the Google Play Store-->
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,534 Points 20k badge 2x thumb
John: his phone doesn't run Android :P I doubt he'll be able to use Refresh apps, hehe
Photo of Ivan
Ivan, Mobile Master
  • 95,532 Points 50k badge 2x thumb
Have you tried transferring the music files directly to the card without using the phone (via micro-to-standard SD adapter) and then inserting the card into the phone?
Photo of rikkster
rikkster, Mobile Master
  • 66,412 Points 50k badge 2x thumb
Try downloading Samsung Kies to your laptop, or if you already have it, update it to the latest version and try transferring music that way.
