Not receiving incoming calls
  • 2
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: *611 or 1-866-995-6636 mentions
Incoming calls are going straight to voicemail. I'm a very low-usage customer, communicating mainly through my home phone and e-mail, but I do want to be able to receive incoming calls in case of emergencies. What do I need to do
Photo of Rob Dresser
Rob Dresser
  • 90 Points 75 badge 2x thumb
  • 2
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,636 Points 100k badge 2x thumb
Can you place calls? Does the phone have a sim card (HSPA) or not (CDMA)?
Rob Dresser
No, I can place calls just fine. It's incoming calls that go directly to voicemail.
If your phone does not have a sim card dial *79 and press send. This will disable do not disturb mode.
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Rob, if you are still having issues, please give our Technical Support a call (*611 Option 6).
________________________
I am having the same problem. I called customer service yesterday and all i was told is that they will make a note of it. My mobile is my primary phone and i cant afford this to keep happening
Mine is doing this. Has been ever since I got it! What a horrible mistake it was to switch to koodoo. Called so called customer service as well and was rold they reset the connection which should fix it. It hasn't. I don't see why they refuse to gice credits when customers aren't even getting proper service!! :(
Photo of Racquel Shaw
Racquel Shaw
  • 224 Points 100 badge 2x thumb
I'm having similar issue. My daughter's teacher called me and said it went straight to vm. My bf also says he's called several times and it will usually go to vm. This is my primary phone and I can't be missing calls from the school like this!
Photo of Naomi Jacobs
Naomi Jacobs
  • 62 Points
My husband is also having the same problem. When calling him it goes straight to vm and does not register on his phone that he has received a call. I need to call him right back again for it to ring through, so this is not a DnD issue or a problem just with my number. I am also with Koodo.
Are you sure? If you call right back and get through that sounds EXACTLY like a do not disturb issue.
