Not registered on network?
  • 2
Every time I try to dial a number on my koodo phone I get message " phone no registered on network" what is that about?
Photo of Vincent White
Vincent White
  • 80 Points 75 badge 2x thumb
  • 2
Photo of Sophia
Sophia, Mobile Master
  • 140,672 Points 100k badge 2x thumb
What plan do you have, Vincent? If it is prepaid, could it be that your baseplan expired? Or if your phone is not connected to Koodo and your plan is active, did you try to manually select the Koodo network?
Photo of Curtules
  • 19,666 Points 10k badge 2x thumb
Often if the phone say that it's not registered on the network it's because 3G is off or 2G/GSM only is on, depending on the phone.
What phone are you using?
Photo of Mary Swanson
Mary Swanson
  • 62 Points
I have a samsung note II and mine is doing same thing
