not receiving data alerts
  • Updated 1 year ago
I don't use very much data, and often days go by in between using it.  However, I never receive a data alert telling me I'm at 50% or 90%; I only ever get one at 100% telling me my data has been turned off.  Does anyone else have this problem?  How do I get the other data alerts?  I hardly ever use all my data, but it's still annoying.
Photo of Cato Hound
Cato Hound
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 56,976 Points 50k badge 2x thumb
Login to self serve, click on usage, then under data click on change data alerts. Here youll be able to set your alerts to give you ones at 50, 90 and 100 like you wanted!
Photo of Cato Hound
Cato Hound
Yes, I've done that many times.  I still only get the 100% alert.
Photo of David
David, Mobile Master
  • 89,034 Points 50k badge 2x thumb
There is also a tool on your phone which will catalog your data use. It may not be exactly the same as Koodo calculates, but it will let you know generally where you are within the month. It is in accurate if you send a lot of pictures by text, as the phone app counts that as data, but Koodo does not.
Photo of Cato Hound
Cato Hound
My phone's kinda old, pretty sure it doesn't track data use.  I can't find it anywhere at least.  Otherwise, good suggestion, but I'd still like a service that koodo supposedly provides to function properly.
Photo of Jru Gordon
Jru Gordon
  • 9,038 Points 5k badge 2x thumb
The issue with the data tracking tool on your phone is that includes pictures being sent as data, so it counts that.  So if you send 1000 pictures, your phone will see that as data and you'll get a warning WAY sooner than what Koodo will send you, as Koodo doesn't bill you for sending picture messages.
Photo of Cato Hound
Cato Hound
Yeah, I just looked up my phone on samsung's site.  I'd need to download an app to track data usage cause there's no built in tool.  Like I said, that's all well and good, but I'm supposed to be getting alerts from koodo, and I'm not.  That's the issue.
Photo of Dennis
Dennis, Mobile Master
  • 187,648 Points 100k badge 2x thumb
Try to uncheck the boxes for the 50 and 90% notifications.  Save.  Then log out and log back in and re check those boxes.  Let see if that resets the system
Photo of Cato Hound
Cato Hound
I have tried doing that in the past and I did it again when it happened the last time.  I'll have to wait until next billing cycle to see if it works, but i know it didn't work last time.  Thanks for the suggestion.
Photo of Dennis
  • 187,512 Points 100k badge 2x thumb
If it doesnt work, I suggest sending Kodoo a facebook private message and someone there would be able to check the back end for ya
Photo of Allan
  • 56,556 Points 50k badge 2x thumb
