Not receiving calls on Moto G.
  • 3
moto g phone keeps missing calls, I dont get any of my calls when I check my phone it says missed calls but my phone didnt ring.
is there some setting that i need to change or is it hardware problem?
Photo of Sain Lunaticx
Sain Lunaticx
  • 90 Points 75 badge 2x thumb
  • frustrated
  • 3
Photo of rikkster
rikkster, Mobile Master
The phone could be set to Silent mode. See the heading "Adjust Ringtone volume" in link below.
https://motorola-global-portal.custhe...
Photo of B2theden
B2theden
  • 2,626 Points 2k badge 2x thumb
Prepaid or Plan?
Photo of matthew sider
matthew sider
  • 746 Points 500 badge 2x thumb
There may things may be your Sim card do you have singel form towers if this happens just software reset
fixes lot of problems I hope this helps
Photo of B-Worrall
B-Worrall
  • 1,430 Points 1k badge 2x thumb
You can also do an easy check to see if your phone is never getting calls or you're just missing them. Just have a friend call you when you're in the same room. If it's a SIM card problem I believe the call will go straight to voicemail and not be ringing from your friends perspective.
