Not connecting to network
  • Updated 8 months ago
Cant call text or use data. LGG5. Shows full bars on phone, but when I try to call I get a message of either 7um1 or 7um3, which say either not activated or not registered on network. I've tried resetting, removing battery and simcard, no change. Tried checking airplane mode. under mobile networks I havetried to reselect network operator to koodo lte, but it wont register.
Photo of Ryan Chiasson
Ryan Chiasson
Posted 8 months ago
Photo of Dennis
Dennis, Mobile Master
Is your account all paid and active?  Try loggin into self serve and see what it says
Ryan Chiasson
Yes it is.
Photo of Dennis
  • 186,618 Points 100k badge 2x thumb
Then there is 2 likely possibilities here.  Either it's the phone or the sim.  Are you able to try your sim in another koodo/unlocked phone?  Or try a working Koodo sim in your phone?
Photo of Dinh
Dinh, Mobile Master
  • 32,630 Points 20k badge 2x thumb
It is likely an issue with the account on the network, not the phone. You should call Koodo 611 or if it is not possible then ask them on facebook.
