No way to check recent incoming/outgoing call details?
  • 2
Is there a way to see the recent incoming/outgoing calls? Do I have to wait for the invoice at month end before I can see all the call details?
Photo of Gene Guan
Gene Guan
  • 2
You should have a call log on your phone.
Photo of Gene Guan
Gene Guan
Thanks but the line is open for my daughter.
Photo of Chris Petersens
Chris Petersens
It's also online, under airtime details/usage tab.
Photo of Gene Guan
Gene Guan
I can only see "Usage" - "Unbilled airtime usage", which shows the number of minutes used but no phone#'s
So you want to spy on your daughter? If it's an android phone you could try an app like android lost. It has a website which will let you get the call information from the phone over the net. You'll need her Google account password and information to set it up. But it's silent when you use it. It can even be hidden from the apps list.
To be fair though, you should make her aware that you have access to her calls and texts. Otherwise you're just invading her privacy and violating her trust in you. Just let her know that you can see anytime who she's communicating with and where she is.
It's a good thing to have on a phone anyway in case you loose it or the worst case scenario, you can't find the user.
