No Sound from phone
  • 2
There is no volume on my phone-ring or text- the vibrate works but no sound? Any help, besides the obvious side buttons that say the volume is at max
Photo of Pat Bayliff
Pat Bayliff
  • 80 Points 75 badge 2x thumb
  • frustrated
  • 2
Photo of rikkster
rikkster, Mobile Master
If you own an Android device, drag your finger from the top of the screen downward (windowshade mode) and check to see that you haven't set your device to vibrate only. By tapping on the Sound icon you can change from vibrate to mute to sound. You want the sound setting.
Or you can go into:
Settings > Sound > Volumes and make volume adjustments there.
Photo of Robert
Robert, Mobile Master
  • 103,858 Points 100k badge 2x thumb
Hello Pat.
If you're on an iPhone, just disable the silence switch on top right of the phone.
