NO sound for notifications - messaging & e mail
Samsung Galaxy Ace 11X has no sound for notifications (E mail & text messages). In setting I don't know how I can de mute. the icon shows it as muted. HELP please
Photo of Betita Bonita
Betita Bonita
There's a volume control on the right side of the device. Press and hold the top of it and the notification volume should be adjusted.
Also press and hold the power button until a dialog box oops up. Make sure you're not in silent mode.
Betita Bonita
the volume on my samsung galaxy ace 2 is on the left side, but it adjust the overall sound volume. All my sounds work except for notifications. The power button only brings up "flight mode, silent mode, etc. Again, it is overall sound. All my sounds work except for notifications. The main screen has an icon in the upper left corner that indicates mute I believe, but everyting works fine except for notifications. thx
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,132 Points 100k badge 2x thumb
Tap on the notification bar at the top of the screen and drag down.
drag the row of green icons to the left
you will see an icon for notifications
tap it so it turns green.
your notifications should be back on now.
Betita Bonita
thanks sooooo much Timo. You can't even imagine how much time I've spent on this one.... and asking people. You are a wonderful person. Thanks again. All the best. Cheers. Dave Allis
Photo of Andrew Martin
Andrew Martin
  • 60 Points
Thanks so much I used this info and managed to get my sound working I understood all your instructions great info.
