no signal
  • 3
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 1-866
I just activated a prepaid on iphone 3Gs, but got no signal why?
Photo of Oiy Srevichai
Oiy Srevichai
  • indifferent
  • 3
Photo of Curtules
Curtules
  • 19,666 Points 10k badge 2x thumb
Is the phone unlocked? Also make sure that 3G is enabled under settings->general->network->enable 3G.
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
If you're not getting signal everywhere, if so, it may be phone problem, if only in one location turn iPHONE off/on,pull SIM, enable 3G like Curtules suggested if not working call 1-866-995-6636 to check coverage and troubleshoot
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
it can take up to 24hrs for your phone to become active but usually comes to life in anywhere from 15 minutes to 2hrs. just turn the phone off and take out the SIM Card and wait a minute or so and then replace it and try again like Mat suggested.
Also make sure airplane mode isn't on and that it isn't on GSM or 2g only like curtules said.
Photo of Dennis
Dennis, Mobile Master
  • 187,648 Points 100k badge 2x thumb
If it is an unlocked iPhone 3GS, you maye need to setup your iPhone via iTunes.
Check out the instructions here:
http://koodomobile.com/en/on/switch2k...
Photo of Achraf Guemmah
Achraf Guemmah
  • 72 Points
Lorsque je fait désactivé le 3G y'a plus de signal ? C'est normal ?
Photo of Curtules
Curtules
Actuellement c'est normal chez Koodo d'avoir aucun signal si vous avez désactivé le 3G.
Koodo utilize une réseau 3G et non 2G pour la service cellulaire.
Achraf Guemmah
  • 72 Points
Ah, ça consomme beaucoup l'autonomie de la batterie :)
Merci beaucoup
