no network
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 1-866
I changed my sim card from iphone 4s to iphone 5, my sim is already registered on koodo website but i don't know why my phone can't find the network and my phone is not avaliable. why? can you please check? thanks
Photo of Remo Roberto
Remo Roberto
  • 80 Points 75 badge 2x thumb
  • sad
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
Iphone 5? very nice!
1. Have you synced your new Iphone with Itunes? (updates carrier settings)
2. Was the iphone 5 on when you put the sim card in?
if the answer for 1 was yes and the answer was "off" for number 2 then try turning airplane mode on for a minute then turn it off. it should reconnect to the network. if all that fails then call tech support
Photo of Robert
Robert, Mobile Master
  • 103,372 Points 100k badge 2x thumb
Hello Remo.
You know iPhone 4S and 5 don't have the same SIM card, do you? Because it seems that you are talking as if you took the iPhone 4S SIM and put it in the iPhone 5. This could be a reason it doesn't work.
If not, try what Tyler said. Keep us updated!
Zaphod Beeblebrox
Now that I think about it, the iphone 5 does take a different sim...maybe. I think the 4s was the last one to take a micro sim and iphone 5 takes nano sim
Remo Roberto
I solve the problem by turning off LTE. Of I switch on LTE I don't have network.
Photo of Robert
  • 103,230 Points 100k badge 2x thumb
This is really weird but is is a known problem. Let the LTE be stable all over your region and it should be fine! Experienced those problems too when switching from 3G to LTE or vice-versa!
http://www.iphoneincanada.ca/iphone-5...
Photo of Aggie Cudmore
Aggie Cudmore
  • 60 Points
l am getting the same problem not registered on network. how do l contact tech support?
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Aggie, you can give us a call from another phone to 1-866-995-6636 and our Tech Support will assist you :).
