No data connection
I just switched over to Koodo and my calling and texting services work, however I'm not getting any data reception. How come? My billing cycle doesn't start until next week, if that helps.
Photo of Avneet Dhaliwal
Avneet Dhaliwal
  • 90 Points 75 badge 2x thumb
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
Are you using an unlocked phone with Koodo?
If so, the apn settings would need to be entered in the phone.
Just so we know exactly what steps to provide, what kind of phone do you have?
Photo of Danno
Danno
  • 810 Points 500 badge 2x thumb
If the Android phone works and data doesn't then confirm you are using APN sp.koodo.com .
You may need to remove the Proxy and Port from the APN. Leave the MMS proxy and port as they are.
Avneet Dhaliwal
I have a Samsung Galaxy Nexus
Zaphod Beeblebrox
check this out
http://koodomobile.com/en/ab/non-kood...
that should assist you in setting up the Koodo APN
Zaphod Beeblebrox
If not, here you go
APN: sp.koodo.com
Proxy server: 74.49.0.18
Port: 80
Username: leave blank
Password: leave blank
Server: leave blank
MMSC: http://aliasredirect.net/proxy/koodo/ mmsc
Port: 80
MCC: 302
MNC: 220
Authentication type: None
APN type: leave blank
Photo of John Lee
John Lee
Hey Avneet! Was your problem solved using the apn that Tyler left you?
Avneet Dhaliwal
Yep! Got it up and running right away! Thanks a bunch
