No Coverage in Canada Now After Using Internationally
  • Updated 6 years ago
I was able to use my mobile in the UK after opting for the LDS International text and calling. However, now that i am back in Canada, I am not able to connect to the Koodo network at all (no connectivity at all). I have tried taking both the battery and SIM card and putting them back in, but that did not help. Ironically, when I take out the SIM card, I do get bars indicating connectivity. Any advice?
Photo of Jeanette Ratz
Jeanette Ratz
  • 80 Points 75 badge 2x thumb
Posted 6 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,220 Points 100k badge 2x thumb
What kind of phone do you have?
Depending on your phone, goto settings and networks and set the phone to select the network automatically. If you're still having trouble, scan the networks manually and select Koodo / Telus
make sure "use 2g only" or "GSM Only" aren't selected
Jeanette Ratz
I have a Samsung Evergreen. I have tried changing the network to manual; no dice.
Photo of Shawn Wood
Shawn Wood
  • 156 Points 100 badge 2x thumb
Might be a long shot, but you may want to hit up your local koodo store and grab a new sim card...
Photo of Yannick
Yannick
Hi Jeanette, before going to a Koodo store, you should give a call to our technical support. We can be reached at 1-866-995-6636 from a landline, option #6. A rep will have a look at it :)
