I cannot send pictures with Blackberry Curve
  • (Edited)
Is it in the Koodo plan to add the ability to send and receive picture messages when using a Blackberry curve smartphone? I feel that I am paying for a service I cannot have. Is that fair? I should have been told that this cell phone was not compatible with the plan I was buying when it came to picture messaging! If I can't send ad receive pictures, could I get a plan that reflects that?
Photo of Suzanne Wernli
Suzanne Wernli
  • 196 Points 100 badge 2x thumb
  • frustrated
I don't think the curve 3g is capable of it.
Buying a phone these days is a lot like buying a car. You don't buy a sun fire if you need a caravan. It's the same with phones.
Every plan includes picture messaging but the device has to be capable. If you just got the device within 14 days, you can return it and get something else. Otherwise it's yours and you'll just have to get a better phone on your dime or use a messaging app like whatsapp with your friends.
Photo of Ry
Ry
  • 5,552 Points 5k badge 2x thumb
Curve 3G can do mms. Afiak, the limitation on the cdma curve is documented right under the nitty gritty
Suzanne Wernli
How does one turn on MMS on a BB curve? And then, is that going to solve the problem? Koodo support says: "If you’re currently using a BlackBerry CurveTM or BoldTM smartphone, you'll only be able to make calls and send text messages. Data is only available using Wi-Fi®. Picture messaging is currently not supported by Koodo Prepaid." Are pictures considered data then?
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
Yes. Pictures are considered data.
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
You need to have data on in order to send or receive pictures. You plan would also need to have a data feature
Photo of Starfox
Starfox
  • 5,718 Points 5k badge 2x thumb
Just so you know, most plans include unlimited picture messaging so technically you are not paying extra for it. Fairness isn't really relevant
Suzanne Wernli
OK then, still frustrated though.
Zaphod Beeblebrox
Do you have a data block on you Koodo account?
Is your phone an unlocked device?
Suzanne Wernli
Not sure :! How do I check for that?
Zaphod Beeblebrox
How did you aquire the phone?
When you log into your Self Serv e, if you have one set up, go to Plans and Add-ons. The overview will show you your plan and current features. Look for the data block. If you do not see it there, feel free to call Koodo at 1-866-995-6636 option 5 or option 6 to confirm the block or not.
Suzanne Wernli
You are a genius! Thanks to you I found that I could add-0n Data Saver Blackberry Access and be able to send pics :) MERCI!
Zaphod Beeblebrox
You are welcome :)
I stand corrected however the rest of my statement stands. Research is key. I guess it was the bold that wasn't capable. Since the information is no longer there.
Photo of Ry
Ry
I agree, research is key
