I still am unable to get a clear signal in my place of resident this happen after I had the data block on my phone. can you place unblock the data so I can get my signal back on my phone again please reply to my e-mail many bless Jackie
Photo of Jj Dunlop
Jj Dunlop
  • 90 Points 75 badge 2x thumb
Photo of Ahmad
  • 96,062 Points 50k badge 2x thumb
If you had Koodo place a data block, you can remove it yourself via self-serve by going to the change add-on's section. If you blocked data through your phones settings, you need to do that yourself from the phone.
If you want Koodo to do this for you, you can call them at *611 from your Koodo phone but they will charge you a fee to do so since you can do it yourself on self-serve.
Photo of Dennis
Dennis, Mobile Master
  • 178,130 Points 100k badge 2x thumb
Hi Jj Dunlop. I'm just going to change this from an Idea to a Question
Photo of Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Jackie, can you check in your phone if 3G is on (in Network Settings)? That could explain why your phone doesn't work. Thank you!
