No roaming plan while overseas, are incoming texts still free?
  • Updated 7 months ago
I missed adding the TXT15 plan by a day and the new roaming package doesn't suit my needs.  I see outgoing texts are 60 cents each but would like to confirm that incoming texts are free without a package of any type.  Thx.
Photo of Kat1972
Kat1972
  • 82 Points 75 badge 2x thumb
Posted 7 months ago
Photo of Bernard
Bernard, Official Rep
  • 75,642 Points 50k badge 2x thumb
@Kat, incoming text message are free. Always. With or without Easy Roam. That said Easy Roam gives you access to unlimited text since you plan has that. It also gives you access to the 750 minutes you have in your plan. And data. Indeed the choice is yours though, based on your needs.whether pay-per-use or Easy Roam that suits you better.
Photo of Kat1972
Kat1972
Thank you so much for the clarification!  : )
