No koodo home phone message Indicator?
  • 2
  • Updated 1 year ago
I now have koodo home phone. Very happy with the quality and savings over my old land line however have one complaint. When someone leaves a message the message indicator on the phone no longer flashes like it used to with my old land line. Is this a limitation or is there something I can do in the setup to get it to flash.
I don't want to have to check the voicemail all the time "just in case". My handsets are uniden dcx 750's. Older yes but reliable.
Photo of zapata rigoreto
zapata rigoreto
  • 232 Points 100 badge 2x thumb
Posted 1 year ago
  • 2
Photo of Sophia
Sophia, Mobile Master
Yeah sadly that doesn't happen with our line either. The only way to see if there are voice messages is on the device itself... so we just taught ourselves to check that when we come home.
Photo of David
David, Mobile Master
  • 89,034 Points 50k badge 2x thumb
Does the device play an intermittent dial tone when VM are received? Otherwise, here is the indicator Sophia mentioned:
Photo of John Littlejohn
John Littlejohn
  • 60 Points
How do you check your voicemail on the Koodo home phone?  Do you have to dial a number or press a button to get into the voicemail?
zapata rigoreto
Unfortunately the phone modem is in my IT closet so not convenient to check. Never noticed an intermittent dial tone either. Ah well I guess I'll have to check for voicemails periodically. Thanks for the replies
zapata rigoreto
SOLVED !
I tried using a more modern DECT 6.0 cordless phone and indeed the light flashes on it. I guess I'll have to upgrade a few of my older uniden handsets.
Zappy's happy.......
Photo of Dave
Dave
  • 60 Points
I have an AT&T Dect 6.0 phone but do not get any indications of messages eitheron it or Northern telecom corded 390 model phones. like you my unit is at the panel so it power all the old jacks in the house to use three handsets.  What brand of phone did you get to work may need to upgrade.
zapata rigoreto
I am using Panasonic KX TGA641C model phones. Not that new but I do get the flashing light and dial tone indicator on them.
