No internet on my unlocked LGV20 help me please and walk me through what I need to do
  • Updated 7 months ago
Need Help. I have an LGV 20 unlocked from sprint and currently using a T-Mobile Sim car right now however I am not getting any Internet 4G LTE on this phone can anybody help me and walk me through what I need to do
Photo of Gino P
Gino P
  • 80 Points 75 badge 2x thumb
Posted 7 months ago
Photo of Dinh
Dinh, Mobile Master
  • 32,762 Points 20k badge 2x thumb
Hello American, the first thing you have to do is to go to either Sprint or T-Mobile forum, and post the question there.
Photo of Goran
Goran, Mobile Master
  • 90,490 Points 50k badge 2x thumb
Check your APN settings to make sure they match up with whatever it is for T-Mobile. You can try resetting network settings as well. You can create a new APN for T-Mobile and then restart your phone. If that doesn't work I'd suggest contacting T-Mobile support at that point.
Photo of Gino P
Gino P
Ok how do you reset all this or add APN? I’m not that Savvy
Photo of Goran
Here is for the APN: https://support.t-mobile.com/docs/DOC...
For resetting network settings go to Settings, backup and reset, reset network settings. It'll also delete any saved WiFi and BT credentials.
The T-Mobile link also has chat support right there if it doesn't work.
