no audio in calls
  • 2
I have a galaxy s4 with the latest version of android and when i make/receive calls i cant hear the other person and they cant hear me. Ive looked in the settings and found nothing and tried turning ot off and back on what do i do?
Photo of will
will
Posted 3 years ago
  • 2
Are you connected to any bluetooth devices?
Photo of will
will
Nope
Photo of Tayeb A
Tayeb A, Employee
  • 18,164 Points 10k badge 2x thumb
Hey there,
Do you still need help? I suggest to pull the battery out for few seconds or press the power button for 30 seconds (wait for the phone to turn off and reboot).
You can call 1-866-995-6636 and press 6 to reach our Technical Support for an immediate assistance.
Our hours of operation are:
Monday – Friday: 9am - 9pm
Saturday: 9am - 7pm
Sunday: 9am - 7pm
A Representative will guide you through the troubleshooting steps.
Hope this helps!
Photo of will
will
I still need help I went through all my settings did the battery thing and fried a factory reset stI'll nothing. I can't call tecynical support number because my phone isn't working properly
How long ago did you get your device?
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Is there friend or family member you can borrow a phone?
Or is there Koodo store near you? They can take a look your phone and/or should help you call Tech support.
Photo of rikkster
rikkster, Mobile Master
  • 67,080 Points 50k badge 2x thumb
Reading through some of the S4 support forums some have mentioned toggling Airplane Mode on and off as a fix. Longshot, but worth trying. Failing that, it would appear to be a hardware problem. Your best option would be to either exchange the device if you're within the fifteen day return period, or have the repair done under warranty if the phone is less than a year old.
Photo of Robert
Robert, Mobile Master
  • 103,644 Points 100k badge 2x thumb
May i suggest to put the call on speaker? Maybe the earpiece isn't working but the speaker is!?
Photo of will
will
Already tried speaker too
How long ago did you buy your device from Koodo?
Photo of will
will
Just over a year
Unfortunately, if it's over one year your phone is out of warranty. So your only options here are to pay for repair or buy a new phone.
