Nexus 5 Reception
Hi,
I just got a Nexus 5 from kijiji, it does not seem to have any damages or water damage however I am getting an orange reception bar for my network and a wifi. At home I cant even connect to the wifi.
My service however worked perfectly well on my previous phone Samsung galaxy s2x
Any help is much appreciated.
Photo of David Park
David Park
  • 220 Points 100 badge 2x thumb
Try restarting your router and see if the problem persists
Photo of David Park
David Park
I will give that a try when I get home however wouldnt my mobile network be unaffected by the wifi reception?
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
That is correct.
Photo of Dennis
Dennis, Mobile Master
  • 187,616 Points 100k badge 2x thumb
Just quickly check and make sure your phone was not reported lost or stolen.
http://www.protectyourdata.ca/check-t...
Photo of David Park
David Park
I just checked and it says it was not reported as lost or stolen
Photo of David Park
David Park
Could it be a SIM card problem?
Photo of Rocky Balboa
Rocky Balboa
Try a factory reset on it. Seems as though the wifi in the phone is not functioning like it should. Can you connect to any other wifi hotspots other then at your house?
Photo of David Park
David Park
I have tried factory resetting it multiple times however it cannot connect in my home I can connect to my school wifi for a limited time however it is very slow. For my home it keeps stating authentication error and the bar drastically decreases when I am about to connect then goes back to max when it is not connecting to it.
Also is the bars on the signal strength for wifi and the mobile network suppose to be orange?
If someone with a stock Koodo sold nexus 5 could check the baseband and make sure they match. You may have a baseband (modem) from outside of North America. There's no way to know without checking a stock unit.
Photo of David Park
David Park
Is there no solution for this then? Apparently it worked quite well on Bell's network
Do you have the box? The should be a code on it d820 or d821.
0= north America
1 = European
Photo of David Park
David Park
the phone and the box say the model is d820 so its should be the american one
Hopefully someone will chime in with the correct baseband version so we can be sure wait wasn't altered. If not..you may be looking at the reason for the sale of the phone.
Photo of rikkster
rikkster, Mobile Master
  • 67,084 Points 50k badge 2x thumb
The D820/D821 KRT16M modems have matching md5 sums.This means D821 users can flash D820 modems. Since they are the same modem, you could try flashing a different radio image to see which performs best. I don't know your level of technical expertise, but I've provided a couple of links that should shed a little more light on the subject.
D820
GSM: 850/900/1800/1900 MHz
CDMA: Band Class: 0/1/10
WCDMA: Bands: 1/2/4/5/6/8/19
LTE: Bands: 1/2/4/5/17/19/25/26/41
D821
LTE: Bands: 1/3/5/7/8/20
M8974A-1.0.25.0.17 (KRT16M) works with both D820 and D821, you could try D820 KOT49E (4.4.1), M8974A-1.0.25.0.23.
http://forum.xda-developers.com/showt...
http://downloads.codefi.re/autoprime/...
https://developers.google.com/android...
Edit: This is also OS dependent (Kit Kat 4.4 or 4.4.2)
Photo of David Park
David Park
Would this involve me rooting the phone? and wouldnt that void my warranty?
You've already mentioned that the device had been rooted and unrooted, once it was rooted the warranty would be void. Did the seller give you the bill of sale?
Also I don't believe the warranty is transferable from the original purchaser
I may be wrong since this is a nexus device but I don't think I am
Photo of David Park
David Park
It was purchased from a third party retailer with extended warranty, I do have the receipt as well
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,448 Points 100k badge 2x thumb
What 3rd party retailer was it ?
What's the model # ? If you don't know go to settings - about phone - regulatory info and I will show beside IC
Here's the other info you should be showing
If you don't have the same model here D820 then you have the European model.
Photo of David Park
David Park
Thank you everyone for your help, so despite having orange bars I seem to receive all my texts and can browse the internet with a little difficulty (However my texts and calls are working quite well). My wifi was connected through using the WPS security bypass and for some reason my signal bars and wifi bars only turn white when I am connected to the wifi at home
