Nexus 4 speedtest
Hello,
Since I have the Nexus 4 with koodo, I am unable to do a speedtest . It always says no connection available (Something like that...) .
Data works though but i dont know if its hspa+ or better....
I there something I need to do ?
thanks
Photo of Jonathan P
Jonathan P
  • 230 Points 100 badge 2x thumb
Photo of Robert
Robert, Mobile Master
  • 103,644 Points 100k badge 2x thumb
Hello Jonathan.
What site are you using? Speedtest.net? Have you tried download the app from speedtest?
Photo of Jonathan P
Jonathan P
Yes its from speedtest.net and i downloaded the app...
Photo of Jonathan I
Jonathan I, Mobile Master
Does your data work with everything else? It could be the APN settings...
Photo of Jonathan P
Jonathan P
Yes it works but often when i go on facebook app...it takes a long time to update the wall and it even says no connection on top of wall (50% of time)
I am in Montréal so its not like if there is no network...
ps: I used the apn settings written on koodo's website
Photo of John Burke
John Burke, Mobile Master
That's odd, are you on stock Android? 4.2.1 or 4.2.2?
Did you switch LTE on before updating to 4.2.2? If so, trying disabling it manually since it's already no longer supported.
Try removing the proxy setting from the apn (the first set not the mms proxy)
Photo of Jonathan P
Jonathan P
OK I will try removing the first proxy setting. I am on 4.2.2. I did tried LTE on 4.2.1 but now it is always staying at WCDMA preffered.. How can I manually disable LTE ?
Photo of Yannick
Yannick
  • 43,998 Points 20k badge 2x thumb
Hi Jonathan, since your phone is not a Koodo-phone, we can only provide limited support. I found this page online though: http://koo.do/Wq98gr. Hope it helps :)
Photo of John Burke
That wouldn't work since Sprint's isn't the same as a "true" Nexus device.
Photo of samsvoc
samsvoc
  • 7,686 Points 5k badge 2x thumb
I believe 4.2.2 no longer supports lte.
I was able to do a speed test with data enabled but not wifi. Later found out that if you remove the first proxy 74.49.0.18 and Port 80, you'll be able to do a speed test with wifi anyway. Hope this helps
Forgive my ignorance but won't that just treat your wifi speed?
Photo of samsvoc
samsvoc
yup
