Nexus 4 Screen broke, need contacts
i dropped my nexus 4 and broke the screen, i need to contacts off the phone. when i plugged it into my computer, it popped up but it says theres no data because i cant get back the lock screen on my phone do to the screen no working is there any solution here?
Photo of Clifford Isenor
Clifford Isenor
  • 132 Points 100 badge 2x thumb
Photo of Rocky Balboa
Rocky Balboa
Did you save the contacts to your sim card or phone?If you saved in the phone you can use a USB cable and plug your phone into a computer to try and retrieve that information.
Photo of Jonathan I
Jonathan I, Mobile Master
Did you... read his post? He already tried plugging the phone into his computer but since the password is on it he can't access any info on his computer.
Photo of Jonathan I
https://www.google.com/android/device...
You could try resetting the password through that if it's connected to the internet but that will enable another lock so I'm not unsure if you can unlock your device remotely at this point. this is why you always save your contacts to your Gmail account so they'll be, for the most part, indefinite.
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,808 Points 50k badge 2x thumb
Doesn't the Nexus 4 save all contacts to the google account? When I added all my contacts, it only gave me the option of my gmail.
Clifford Isenor
it likely does, but apparently i did not select that option
Photo of e-wizard
e-wizard
  • 350 Points 250 badge 2x thumb
Hate to say that, but it seems like the only solution is to get a replacement screen. You can't reboot the phone to by-pass the password, because you lose the info. And if contacts are not backed up on gmail, you can't access them either way.
Photo of Ivan
Ivan, Mobile Master
Doesn't seem like a worthwhile solution to me, unless he has no other way to get those contacts' information.
Rocky Balboa
Data recovery specialist maybe?But can they do that with cell phones?
Photo of Brendan William
Brendan William
  • 732 Points 500 badge 2x thumb
They may have synced to your Google Account.. check here
https://www.google.ca/contacts/
