nexus 4 problems PLEASEEE HELLPPP
hi i got a nexus 4 for christimas i crackedhe teh screen and i got it fixed and then when i went to turn the phone on it had a system glich and then i took ut to koodo in brampton and they shipped it away and i got it back 2 weeks ago and it worked and then i got it taken away and i got it back last night and i used it for 3-4 hours and then i system update popped up and i clicked it and now it doing the system glich
Photo of Chantelle Walterhouse
Photo of Jonathan I
Jonathan I, Mobile Master
What system glitch would this be? What's the issue?
im not sure because when i go ne sceens for thee phone it would turn on and say good the go to these 4 colous and they would circle around and that all they would do so i shipped it away for free and they fixed it and then i was using it last night and a new system update popped up and i clicked it and nowits doing the same this not going to home screen
google*
Photo of Jonathan I
Have you tried forcing a factory reset? Hold down the volume down (or up, can't remember) and then hold down the power button for about 10 seconds. Let go of the volume button when you feel it vibrate.
Navigate to to wipe data/factory reset option using the volume buttons. Say yes/confirm using the power button to confirm. Then say reboot now. See if it loads.
Warning: this will erase everything on your phone and you can't get it back.
all it says is recovery mode and bootloader and ive done both of thoes
Photo of Yannick
Yannick
Hi Chantelle, the best would be to contact us directly over the phone in order to review your options. We can be reached at 1-866-995-6636 from another phone, option #6. Thank you!
________________________
