Nexus 4 problems
Hey, I am using nexus 4 it is under warranty some time volume button is not working, and the battery life is bad with data on it works for 5 hrs only. What can be the option for replacement
Photo of Utsav sheridan
Utsav sheridan
Photo of John Burke
John Burke, Mobile Master
For battery life, is that 5hrs with the screen on or off?
If on, that's considered quite good.
If off...well yeah, that's pretty bad. A possible problem is Google is having a problem syncing. Go to Settings-> Accounts-> Google then see if there's a red icon indicating something isn't sync'ed properly & try to resync whichever that is.
