Nexus 4 prepaid simcard won't fit in slot?
Bought a prepaid simcard for my nexus 4, the simcard is too big for the slot.
Photo of jeneva rose ☆
jeneva rose ☆
  • frustrated
Photo of Sophia
Sophia, Mobile Master
Hi Jeneva,
There is only one size SIM card for both normal SIM format, and micro SIM (what the Nexus 4 takes). There should be two "cut outs", the bigger one and also the smaller one... try to push it out really carefully and it should fit :)
EDIT Oh wait, I'm confused... that is not how it works with Koodo unfortunately. Are you saying you bought the wrong format? See if you can exchange it at the store, Jeneva, sorry about the confusion :(
(I got too many darn SIM cards, lol)
