Nexus 4 or Nexus 5 Medium tab total monthly pricing?
If I get a Nexus 4 or 5 and use a Medium tab on 30$ a month, how much would it add up to per month? I got 45.48$, which is too much for me. :/
Photo of Paul Nguyen
Paul Nguyen
Photo of Sophia
Sophia, Mobile Master
Hi Paul,
On a medium Tab, you will need to add $5 to your plan. So on a $30 plan, that would make your bill $35 (plus tax) :)
Photo of Some random Mobile Master
Some random Mobile Master, Mobile Master
  • 39,554 Points 20k badge 2x thumb
Paul, the 15% Tab contribution comes from Koodo, not from you. Your own is $5/month on TabMedium. So like Sophia said, it's $30 (plan) + $5 (Tab contribution from you) + 911 fees (likely $0.40) + applicable taxes.
If you're in Quebec, that'd be $40.71 taxes in.
Photo of Mayumi
Mayumi, Mobile Master
  • 115,056 Points 100k badge 2x thumb
Or $39.55 if you are in Ontario (plus overages, if any),
Paul Nguyen
Oh, I get it now, thank you David! I thought the contribution was from my bill -_-.
Paul, I simply broke down what Sophia and Mayumi had answered :) The thanks should be directed to them :) However, let's all be glad you now have a clear answer!
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,220 Points 100k badge 2x thumb
Hey Paul I have the Nexus 4 and the Nexus 5 and it's definitely worth getting the Nexus 5 (black model is so much better with its soft touch rubber edited coating over the back and sides, it's like silk) if at all possible, it's so much better in so many ways.
Just a heads up but the best thanks you can give someone for helping you with your issue is to star the answer or answers that helped you solve your issue.
Photo of Kevin Tran
Kevin Tran
  • 60 Points
Hello Im a little confused. I currently have the Nexus 4 (paid $150) and have $150 on my medium TAB and the $30 talk and text plan. How much would it cost to cancel the plan? Would i just pay off the $150 thats on the TAB?
Thanks a bunch
Photo of Jonathan I
Jonathan I, Mobile Master
The Medium Tab is up to - 300. Since you have $150, it sounds like you're on small Tab. No matter what the case may be, you're responsible for the Tab balance if you cancel.
Photo of Mayumi
Yes. You will pay off remaining of the Tab and overage charges if any :)
Call customer service from your Koodo phone *611 option 5 and request the cancelation.
