Nexus 4 onKoodo
What do I need to do to set up a nexus 4 on Koodo?
Photo of Richard Walsh
Richard Walsh
Photo of Ahmad
Ahmad
You should be able to put your sim card into the N4 and be good to go. You may need to set up your APN settings if they aren't automatic so that your data can work. They are found here: http://koodomobile.com/en/ab/non-kood...
If you need a different sized sim card, you can go to any Koodo kiosk and they can give you the appropriate one and can even switch everything for you. You can also do it on self-serve yourself if you want to take the sim card home and do it yourself or at a later time.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,626 Points 100k badge 2x thumb
If anybody comes to this post because they want to get the Nexus 4 I thought I'd let ppl know that it is available again right now in the Google PlayStore Canada.
There's only a 1-2 week delivery of it this time also. Act quick though because it might sell out again fast, depending on how much LG bumped up their production of it.
