Nexus 4 making odd sound when I move the phone
It started about a month ago that whenever I tilt my phone it will make a very odd sound. I haven't installed any new apps since and the noise is random. I was told to turn off the screen lock sound which that didn't make any difference. The sound happens at different times.
I bought the phone about 6 months ago, should I bring it in for warranty?
Thanks
Photo of Shawn MacGillivary
Shawn MacGillivary
  • 150 Points 100 badge 2x thumb
Photo of John Lee
John Lee
Odd sound? Like from the phone as in a notification type of sound or something mechanical/physical?
Shawn MacGillivary
It's more of a mechanical noise. I have to shake the phone to get it to stop. It's really hard to describe without hearing it.
Shawn MacGillivary
Problem solved it was the NFC feature that was turned on and I had my credit cards in the same holder so it was scanning for the rfid signal.
