nexus4. taking time to get wifi signal,,,like more than 2mins... 5mins
Photo of Sun Woo Kim
Sun Woo Kim
  • 102 Points 100 badge 2x thumb
Is this any wifi signal or a specific signal?
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Hi Sun,
I had a customer with the same issues. There is a new update 4.2.2 that fixes unstability. I recommend that you check the settings and software update.
Sun Woo Kim
Hey guys,,yes its home wifi that quickly connecting to any other devices except
my nexus 4.....
i just got this on sunday now it has 4.4.2 ..
it connected my wifi eventually but it just take too long(2~5mins)
my wife got same one but hers works just fine within 15seconds...
I'll see hows it doing then take it to the kiosk...
Thank you
Before you take it back to the kisok,
On your home wifi router. Pull the black power cord out from the router and wait a few seconds before plugging it back in. This will force it to restart its firmware and connections
Then try to connect to your home wifi again. If this solves your problem you may want to consider putting your home router on a timer to restart it daily when you're normally not home. Ours resets at 3am. We have had problems with our Linksys router and that seemed to solve it.
If you still have issues then on your phone:
Goto settings... Wifi... Longpress your home network... Choose forget....
Now rescan for networks and reconnect
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
I had the same issue when I first got my Nexus 4. After theupdates for the OS, the issues were fixed. I did have to unplug the router for a minute or so.
Sun Woo Kim
Its all of sudden working fine! Weird...
Thank you for your helping anyway . peace ~
