Nexus 6 Plan options!!!
If I buy a Nexus 6 from Google Play can I set it up with a lightweight Canada wide plan or only a prepaid plan. I'm not totally sure how prepaid works but I'm too impatient to wait for Koodo to get the 6.
Photo of Owen Taylor
Owen Taylor
  • 90 Points 75 badge 2x thumb
Photo of Mark Kokolsky
Mark Kokolsky
  • 10,722 Points 10k badge 2x thumb
You can set it up with whatever you want. The only time there is a requirement is if your getting it on the tab, in which case you have to meet the requirements for any of the tab levels. If your buying it from google, you can do it on postpaid or prepaid, its all up to you.
Photo of Erwin
Erwin
  • 23,576 Points 20k badge 2x thumb
Hello Owen,
When you mention "lightweight Canada wide plan," is this the current data rate plan you are on? Normally with Nexus smartphones, they are pre-unlocked, this means you can use whichever service you choose. Either prepaid or postpaid will work with the Nexus 6.
Photo of Du
Du
  • 3,762 Points 3k badge 2x thumb
Remember if you go with postpaid you will get the 10% discount!
Owen Taylor
What's the 10% discount?
Photo of B-Worrall
B-Worrall
  • 1,430 Points 1k badge 2x thumb
10% off your monthly bill
Owen Taylor
Yeah its what I'm on right now. I just wanted to make sure I wouldn't have to switch plans.
