Nexus 5 won't connect to wifi
  • 2
  • Updated 1 year ago
So I switched to Koodo about a month ago, and I'm not able to connect to the Wifi at my school with my Nexus 5 (which I purchased at Koodo). I'm at the school a lot, so this is becoming a problem. I'm almost over my data limit because I have to keep using my data.
I'm able to connect to wifi basically everywhere else. Everyone else I know here is able to connect here at my school.
My phone is a Nexus 5 Android Version 6.0.1
Any suggestions would be greatly appreciated.
Photo of Ash
Ash
  • frustrated
Posted 1 year ago
  • 2
Photo of Allan
Allan, Mobile Master
  • 56,526 Points 50k badge 2x thumb
If you can connect to other wifi connections then the problem is with your schools internet. Go visit your it specialist and ask them if they can fix it for you. I used to work the the it guy at my old high school and he would ban ips that looked suspicious and occasionally banned ones by accident so your best bet would be to talk to them about it!
Photo of David
David, Mobile Master
  • 88,974 Points 50k badge 2x thumb
Have you spoken to the IT staff at the school? It sounds like an issue with the implementation of Wi-Fi at their facility, if it works elsewhere.
Photo of chris
chris
  • 452 Points 250 badge 2x thumb
My friend just recently had same problem with samsung phone that he got while his was in repair. What it was is old phone seemed not to work with his new modem/router at home.
I have old iphone4 and luckily wifi all works but all apps are outdated. Just got upgraded though
Not to offend but i go with motto, "you get what you pay for"
Photo of Allan
There is a small chance that your school uses only 5Ghz for their internet instead of 2.4Ghz and you may have this disabled. Make sure that "2.4 GHz only" isnt set.
Setting > Wireless and Network > WiFi > Tap the Menu button again > Select Advanced/Wi-Fi Frequency Band > Tap 2.4 GHz only.
Photo of Ivan
Ivan, Mobile Master
Rather unlikely. Institutions take forever to move to newer tech. Higher frequencies are also less desirable for larger institutions due to range. Transfer speeds are of lower importance.
Photo of Allan
I said there was a small chance. Just brought this up because the previous comment made a comemnt about older tech and thought i would bring up that the phone may have 5Ghz disabled.
Photo of titaniumtux
titaniumtux
  • 12,912 Points 10k badge 2x thumb
@Allan: agreed with Ivan. Although the Nexus 5 supports dual-band wifi, OP said "I'm able to connect to wifi basically everywhere else", and it'd be even more unlikely that "everywhere else" is set exclusively on 5Ghz.
Photo of Ash
Ash
Thanks everyone. It actually seems to be working now. I went to someone in IT and I don't know why this worked, but they logged in with their own account, which magically worked, then they had me log in with mine again and it worked? I have no idea how, but I'm just glad it's up and running again. I appreciate the help though everyone. What a great community on here.
Thanks again
Photo of Goran
Goran, Mobile Master
  • 88,204 Points 50k badge 2x thumb
Technology is a weird beast. Networks all the more so.
Photo of Ash
Ash
lol absolutely
