nexus 5 overheat and camera not working
  • (Edited)
My phone is lg nexus 5 and its been like 9 months since i bought it and it has some problems it overheats front camera not working and notification led is not working aswell i cracked the screen and replaced it once and cracked it again but i had this issues even before i replaced my first screen does this covered with warranty because i like this phone and i want my problems to be solved i can pay the screen but i want other parts to be fixed by warranty
Photo of Ege Karabacak
Ege Karabacak
  • 82 Points 75 badge 2x thumb
  • sad
Photo of Ahmad
Ahmad
Overheating is a normal thing on any smartphone. It depends on what you're doing, how you're doing it and where you're doing it.
I would go to your closest Koodo kiosk/store and have them take a look at it and they can tell you what your options are from that point. We can't really help you here because we can't see or touch your phone to assess the situation.
Ege Karabacak
Thanks but the problem is it slows itself down like it lags and i dont think playing music while charging can over heat it this much becuse it was not like that when it was new
Photo of Ahmad
Ahmad
Charging your phone and doing anything can overheat it. It also depends what you're keeping it on, etc. I have an electrical engineering background; phones can and will overheat. That's just how it works.
Definitely go to your nearest Koodo and have them check it out for you :)
